Chevrolet Avalanche
Platform: GMT 805 & 900
avalanche help needed desperately
Old Jan 20, 2015 | 11:50 AM
copalanche's Avatar
Default avalanche help needed desperately
About a month ago, my 07 LT died on me. it gave me "Service Stabilitrak, service traction control, low oil pressure, reduced engine power, stop engine".
I erased the codes and it ran just fine for about three weeks. after driving for about 4 hours it did it all again. I disconnected the negative terminal and reinstalled it and it got the last two hours good to Arkansas. I had a new ecm programmed and installed at a Chevrolet dealership, and on the way home from Arkansas around 4 hours into the trip it did it again, in which I put the old ecm back in it since the codes were erased due to not having power. Now it wont do anything with either ECM, and I have No idea where to go from here. Ive heard anything from throttle body sensor to throttle body connector to on star computer
Old Jan 20, 2015 | 10:42 PM
mistaake's Avatar
Grounds? Fuses?
That must be annoying. You're probably best off taking it to a Dealership though - electric problems on advanced trucks like yours are tough to work with.
Old Jan 20, 2015 | 11:28 PM
burhead1's Avatar
Have a look at the connections on the power/tran relay in the under hood fuse panel. you can swap it out with one of the other relays.
Old Jan 21, 2015 | 8:30 AM
copalanche's Avatar
Have either of you ever heard of this? This is causing me to take a cab to work in uniform, and for obvious reasons thats sketchy. So the sooner i fix it the better
cbr6864
Jun 2, 2013 3:27 PM
cmleon
May 15, 2013 8:10 PM
Outlaw91'
Oct 2, 2012 6:50 PM
golfman56
Jul 14, 2006 12:44 AM
