Chevrolet Avalanche
Platform: GMT 805 & 900
Cold engine whins
Old Dec 22, 2011 | 1:34 PM
rbjax's Avatar
Default Cold engine whins
I have a '02 avalanche that makes a whinning noice in the mornings when you first crank up. It is kinda high pitched that goes along with the rpm. After a couple of miles the engine gets warm and the whinning goes away.
Power steering fluid is ok with no leaks and does not make unusal noise when steering wheel is turned either way.
Truck has 132,00 miles on it.
Any ideas?
thanks,
Ron
Old Dec 28, 2011 | 9:06 PM
espop125's Avatar
Mine does the same thIng let me know if you figure it out
Old Dec 28, 2011 | 9:32 PM
adam86107's Avatar
Could just be the belt
Old Dec 29, 2011 | 3:13 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> rbjax,
It may be your drive belt. That is just a suggestion, not a diagnosis. It is difficult to diagnose without a physical inspection. You may want to consider taking the vehicle in. A technician should be able to offer a more accurate solution.
Have a great day!
Please feel free to contact me with any additional questions.
Louis
GM Customer Service
Old Feb 22, 2012 | 10:09 PM
cleveland63b's Avatar
sounds like a belt....make sure to check both the A/C belt is kind of hard to see if you don't take intake ducting off
Old Mar 2, 2012 | 7:45 AM
sancho's Avatar
my 07 with 100,000 miles was doing that, i changed the serpentine belt myself and that fixed the problem. about 30$
Old Apr 23, 2012 | 11:04 AM
AnthonyKeene's Avatar
From my experience, if you can see the fan motor when you have the glove box out, hold on to it while you cycle thru the speeds to see if there is a marked change in vibration at different speeds. If so, you might need a motor.
Anthony
Old Apr 23, 2012 | 9:34 PM
blower motor wouldn't respond to rpm
mdec950
May 11, 2012 9:44 PM
Supertwins
Jul 4, 2011 11:39 AM
Mille Racer 69
17
Nov 7, 2010 4:19 PM
stantonbox
Dec 5, 2007 8:40 AM
ltz02
May 22, 2007 9:18 AM
