Help Wanted - 2010 Avy Shifter Mod
Modernizing my 2010 Avalanche (lowered RWD), adding a 10" floating screen and column shift delete in favor of console shifter from a 2016 Camaro LT1. Because the linkage cable is already inside the cab of the vehicle, I'm hoping the only physical modifications are the column shifter handle delete and fabricating a center console insert that will accommodate new console shifter. My questions are as follows:
- Would the column shifter linkage cable from the column attach to the console shifter with little to no modification?
- How do I go about relocating the Tow Mode button (and associated wiring)?
- How do I splice the Camaro connector to the Avalanche TCM harness?
It is always worth trying new methods, especially when you have a headache that is disabling. And when I heard about the method of hormone replacement therapy that helps with migraines, here https://ways2well.com/blog/can-hormo...duce-migraines, it became my salvation. I no longer have migraines and I feel great and can go about my daily routine without any problems.
johnmcgrady35
May 26, 2021 12:34 AM
