Chevrolet Avalanche
Platform: GMT 805 & 900
Red warning light on dash stays on
Old Feb 23, 2018 | 3:35 PM
Wyocowboy's Avatar
Default Red warning light on dash stays on
2002 Avalanche z71 4x4-- After I remove the ignition key when the engine is off, the red warning light on the upper left of the dash stays on.
Old Feb 23, 2018 | 9:18 PM
which red warning light?
Old Feb 24, 2018 | 12:17 PM
Wyocowboy's Avatar
The big one in the upper left hand corner. It also blinks security when a door is open. But right now it is off when the engine is running but stays red when key is removed.
Old Feb 24, 2018 | 1:59 PM
kevinkpk's Avatar
You have remote door locks?
Old Feb 25, 2018 | 9:50 AM
what symbol is it flashing..post a pic
Old Feb 25, 2018 | 8:10 PM
Wyocowboy's Avatar
It is the message center light. The red light does not flash it stays a solid red when I take the key out. A battery picture is also on in the red light. I have attached 2 photos. One looking thru steering wheel and a close up of the red light.
Attached Thumbnails Red warning light on dash stays on-0225181728a.jpg   Red warning light on dash stays on-0225181729a.jpg
Old Feb 25, 2018 | 9:16 PM
the owners manual will explain each warning symbol.
typically, the battery symbol on all the time after start up indicates a charging system problem.
start the vehicle and check the voltage at the battery with a voltmeter...one lead on each post...red to red, black to black.
running; the system voltage should be approximately 13-15.5 volts. if it is 12.7 or less...the vehicle is not charging.
Old Feb 26, 2018 | 10:52 AM
Wyocowboy's Avatar
Thanks. I will do that. The light does turn off when the engine is running.
Old Feb 26, 2018 | 2:49 PM
kevinkpk's Avatar
Had any problems cranking?
Old Feb 27, 2018 | 9:51 AM
Wyocowboy's Avatar
No but I disconnect the battery overnight and the charge gauge shows about 14 amp when running.
