Chevrolet Avalanche
Platform: GMT 805 & 900
Red warning light on dash stays on
Old Feb 27, 2018 | 9:52 AM
  #11
Wyocowboy's Avatar
Sorry, thought I responded earlier. Yes I have remote door locks
Old Feb 27, 2018 | 8:17 PM
  #12
Originally Posted by Wyocowboy
Thanks. I will do that. The light does turn off when the engine is running.
that is what its supposed to do when its working normally. the battery light when off is a "bulb check".
Old Mar 21, 2018 | 11:20 AM
  #13
Wyocowboy's Avatar
Default Fixed it!
The trouble went back to the installation of the ignition cylinder lock and ignition switch and the casing. Apparently I wasn't careful enough when I took the old switch out and the gears were 3 teeth off when I set the new switch As a last ditch effort, I pulled the new switch and moved the gear 3 teeth towards the dash. Walla! It is fixed! Before when I turned the key off it was not moving the switch far enough to turn the red light off.
