Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
1990 beretta stalling
Old Sep 4, 2008 | 10:54 PM
neisg1's Avatar
Default 1990 beretta stalling
I have a 1990beretta that starts and idles somewhat rough but will stall if you touch the throttle. Have replaced the fuel filter, plugs and wires, swapped out the map and tps with no change. Codes have been checked and nothing was stored.
Any ideas?
Old Sep 8, 2008 | 10:03 PM
neisg1's Avatar
Default RE: 1990 beretta stalling
Changed the coil pack and it no longer stalls but still won't revup properly.
I'm thinking a weak fuel pump?
Old Sep 14, 2008 | 9:06 PM
neisg1's Avatar
Changed the fuel pump and still runs the same.
Old Sep 14, 2008 | 10:20 PM
shawnvw's Avatar
Banned
What motor? could be ignition module...
Old Sep 15, 2008 | 9:48 PM
neisg1's Avatar
It's a 3.1L, the entire coil pack has been replaced and (as far as I know) the module as well.
I'll have to check it actually belongs to a friend and I'm not 100% about the module.
Old Sep 16, 2008 | 3:33 PM
shawnvw's Avatar
Banned
Ign module sits underneather the coils and is a separate unit.
Old Sep 22, 2008 | 9:42 PM
neisg1's Avatar
Yes, the entire coil pack and module were swapped out, this helped somewhat as one of the original coils was weak or intermittent.
However the stalling problem still exists. Also removed the O2 sensor from the manifold temporarily to check if the catalytic was plugged, again no change in the stalling problem. TPS and MAP have also been swapped out.
The next step will be to replace the Crank sensor unless someone else has a better idea.
Old Sep 22, 2008 | 9:59 PM
shawnvw's Avatar
Banned
I think you're on the right track
Old Oct 1, 2008 | 8:09 PM
fatguy's Avatar
Have you been running any ethanol? I have had the same problem with a Cutlass. It turned out one of the injectors was borderline bad and caused this problem. Do you have a scanner of anysort to check the O2 readings while it is running?
Old Oct 7, 2008 | 8:06 PM
neisg1's Avatar
Well we changed out the crank sensor and still no change. Just regular fuel but we are now suspecting the injectors, unfortunately we don't have a scanner that will monitor while running.
Thanks for the comments.
