Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
1990 beretta stalling
Old Nov 8, 2008 | 1:53 PM
  #11
timbalish's Avatar
Default RE: 1990 beretta stalling
I am having same problem, changed many sensors ... starts and idles fine, but touch the gas pedal and it dies.
Old Nov 9, 2008 | 8:22 AM
  #12
shawnvw's Avatar
Banned
whats the fuel pressure running at?
Old Nov 9, 2008 | 12:57 PM
  #13
timbalish's Avatar
I had purchased a gauge and the fuel pressure is good and normal with no drop.
Old Nov 10, 2008 | 9:58 AM
  #14
neisg1's Avatar
ORIGINAL: timbalish
We still haven't solved the problem, changing almost all of the sensors etc. had no effect on the problem. It still stalls when you step on the gas. It will occasional rev up most of the time it dies. I have now been told by another mechanic that an intermittent or bad fuel regulator can cause this and not show any codes. It did pass the basic pressure tests but you know how intermittent problems can be.
The regulator should bypass fuel back to the tank under idle (high vacuum) conditions, when you step on the gas the vacuum drops and the regulator should react by restricting the fuel bypass to provide additional pressure/flow to the injectors.
I haven’t had a chance to look into this yet.
evangella
May 2, 2012 7:24 AM
getz172006
Oct 26, 2008 8:16 PM
drivnovrdaedge
Jun 18, 2008 9:42 PM
clevo
Feb 5, 2008 12:19 PM
getz172006
May 23, 2007 8:07 PM
