Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Advice on Swapping 1991 3.1 into a 1990 Beretta
Old Feb 3, 2008 | 1:13 PM
clevo's Avatar
Default Advice on Swapping 1991 3.1 into a 1990 Beretta
The donor car is a 1991 Corsica , a 1990 Beretta GT is the recipient. I'm thinking it would be a straightforward swap, with the sensors and harnesses matching up between the recipient car an the new engine.Are there any resources for determining engine compatibility where I can find out for sure if everything will match up, and more importantly, work correctly?[/align]
Old Feb 4, 2008 | 7:22 PM
shawnvw's Avatar
Banned
Default RE: Advice on Swapping 1991 3.1 into a 1990 Beretta
I can't remeber when they stopped using the 2.8L on those cars, it was around the late 80's, possibly 1990......if they are both 3.1L....your good to go, all the sensors should all match up
Old Feb 5, 2008 | 12:19 PM
clevo's Avatar
Both engines are3.1L, so thanks for the info on the sensors matching up.
The Beretta has 220,000 miles on it ,but is in very good condition. The Beretta's engine had an interal coolant leak.I'm not sure how long I drove itwith the leak, but whenI started tearing down the engine I saw milk chocolate-colored sludge. Made me consider abandoning the top end gasket change and go with another engine. I guess I could always put it back together and see how long the bearings last.
The Corsica's 3.1 has 90,000 miles on it, and is still in the car. The seller said I could see the engine running before I decided to buy it. He said I could also buy the engine and transmission (it is an automatic like my current transmission) if I was interested in replacing the whole drivetrain.
Would it be wiser to replace the entire powertrain, rather than mating a 90,000 mile engine with a 220,000 mile transmission? I'm thinking I should swap the engine and transmission together to give me the best shot at having a reliable vehicle.
I've also been reminded that the car is worth at most $800 or $900 (in running condition)and thatthe wisest move would be to get rid it. I've had the car since new, enjoy driving it, and have a sentimental attachment to it, even though it is nothing special; it's just a run of-the-mill Beretta GT. That's why I'm considering the repair in the first place.
So if you have any thoughts on replacing the engine and trans vs the engine only, please pass them along.
rney
Jul 1, 2012 11:28 AM
getz172006
Oct 26, 2008 8:16 PM
berettaman91gtz
Nov 28, 2007 11:36 AM
rogerwood
Nov 7, 2006 5:39 AM
