Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
1995 beretta cooling fan problem
Old Oct 5, 2008 | 12:13 PM
Tosha0516's Avatar
Default 1995 beretta cooling fan problem
The fan will come on only when the ac is turned on.I can turn the ac off and the fan will continue to run for awhile. Once it shuts off the car begins to run hot and the ac has to be turned on again for the fan to run. The relays have been checked they are working.I don't know what the problem could be, any help would be appreciated.
Old Oct 5, 2008 | 2:33 PM
jackyshaikh's Avatar
Default RE: 1995 beretta cooling fan problem
It could be ECT (ENGINE COOLANT TEMPERATURE ) Sensor just unplugged the connector of sensor put fused jumper or a resistor and see if it spins.If it does replace the sensor.
Old Oct 5, 2008 | 8:51 PM
Tosha0516's Avatar
Thanks so much.Could you tell me where the ect sensor is located?
Old Oct 6, 2008 | 11:50 AM
Tosha0516's Avatar
as soon as the ect sensor is unplugged the fan will begin to work.
Old Oct 7, 2008 | 2:47 PM
Do you mean when you unplugged the ECT Sensor connector the cooling fan started working without puting fused jumper in conector pins?
Old Oct 8, 2008 | 1:38 PM
Tosha0516's Avatar
Yes, thats exactly what happened. Sorry it took so long to get back.
Old Oct 9, 2008 | 4:28 PM
Never mind.so did you replace ECT sensor?
Old Oct 9, 2008 | 7:54 PM
Tosha0516's Avatar
Yes, that fixed it.Thanks for your help.
Old Apr 2, 2010 | 4:10 PM
heisabud's Avatar
Default A toggle switch
I was having the same problem , I somply installed a off / on switch in the center console. A year or so later I also replaced the two sensors in the thermostat houseing and put in a cooler thermostat.
tom p
Nov 19, 2014 10:26 AM
bass
Feb 8, 2014 8:20 PM
htopball
May 6, 2010 6:00 PM
kaneless
Jan 15, 2008 12:27 PM
xswinnyx
May 13, 2006 1:01 PM
