1999 Lumina Idling problems & Etc.
Hi everyone. I'm new here, and I figured that this is the place where my questions may be answered. I have been having some minor, but annoying problems with my car for quite a while now. First, the car hesitates slightly, sometimes not so slightly, when accelerating from a stop. Also, the engine will sometimes bog down and almost die when coming to a stop. This happens primarily when driving in a city or town (stop & go). Also, it sometimes idles at a high rpm, high enough that the car can go about 25 mph without stepping on the gas. I suppose that this might bea bad sensor, such as a throttle position sensor, MAF or O2 sensor, but I figured that I would ask here and see if anyone else has had similar troubles.
Thanks!
Thanks!
RE: 1999 Lumina Idling problems & Etc.
I have a 96 lumina and it starts hard sometimes chuges and once in a while it will die at a intersection I am going to take it to autozone and have the codes checked I would recomend you do the same other wise you will be replaceing sensors that are not bad and they are not cheap good luck
watchinfaith07
March 12th, 2013 6:03 PM
erinmelissa1230@yahoo.com
March 7th, 2009 8:02 PM
