91 lumina question
i have a 91 lumina with a 3.1 i have been having problems getting the heat to go from defrost to blend or vent etc i have locted the problem along with cruise control not working i found a cracked hard plastic vaccum line i know this is the culprit the the question i have is it came off the other end of the rubber adapter that runs under the plenum the question i have is is there an easy way to get to it or do i need to take off the plenum to get to it. any help and or advice is greatly appreciated old chevy i could use your wisdom on it ty steven
I remember doing something like this.. you can probably reuse the gaskets if you don't disturb them much.
If that becomes a problem, you can always replace the gasket.
Well, my car was only 8 years old then. Your's is 23 years old now.
on my heater problem found a plastic vaccum line was broken on my 91 lumina auto with a 3.1 6 cyl i was able to rerout it with new line and now the heat works great on all settings now which is awesome
ty for the help
ty for the help
Congrats on finding and fixing it!!!
No we are moving too summer
MagicElectric
Feb 27, 2007 3:42 PM
