Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
91 lumina question
Old Mar 18, 2014 | 7:42 AM
rockfan12100's Avatar
Default 91 lumina question
i have a 91 lumina with a 3.1 i have been having problems getting the heat to go from defrost to blend or vent etc i have locted the problem along with cruise control not working i found a cracked hard plastic vaccum line i know this is the culprit the the question i have is it came off the other end of the rubber adapter that runs under the plenum the question i have is is there an easy way to get to it or do i need to take off the plenum to get to it. any help and or advice is greatly appreciated old chevy i could use your wisdom on it ty steven
Old Mar 18, 2014 | 7:13 PM
sledge.impy's Avatar
Yeah, you'll need to take it off.
I remember doing something like this.. you can probably reuse the gaskets if you don't disturb them much.
If that becomes a problem, you can always replace the gasket.
Well, my car was only 8 years old then. Your's is 23 years old now.
Old Apr 2, 2014 | 12:14 PM
Default update
on my heater problem found a plastic vaccum line was broken on my 91 lumina auto with a 3.1 6 cyl i was able to rerout it with new line and now the heat works great on all settings now which is awesome ty for the help
Old Apr 2, 2014 | 10:57 PM
Sounds like it was a vacuum line for the heater door.
Congrats on finding and fixing it!!!
No we are moving too summer
Breze84
Feb 14, 2014 6:45 PM
Breze84
Jan 5, 2014 12:45 AM
ekjetta98
Mar 31, 2008 4:53 PM
larrysteele
Jul 23, 2007 11:56 AM
MagicElectric
Feb 27, 2007 3:42 PM
