Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
91 lumina wont start
Old Aug 23, 2011 | 4:36 PM
motleyman's Avatar
Default 91 lumina wont start
my 91 lumina died on me at a light,had it towed home,started tinkering,had the ignition module tested,it tested good,i am gettin fuel at the valve stem,sprayed startin fluid into the intake,still nothin,it gets spark,i have replaced the coils,and the crank sensor,still wont start,can anyone tell me what i might check
Old Dec 23, 2012 | 3:06 PM
GHOSTOWLGRID's Avatar
You might have a bad injector.
If one goes out, they all get turned off to protect the ECM.
are you getting fuel in the cylinders?
That is the next logical choice considering you have spark.
Fuel pressure is good on the rails right?
Make sure the fuel pressure regulator is not broke and dumping gas up the vacuum line...
sleepingciv
Jul 25, 2020 1:03 PM
motleyman
Jul 10, 2014 10:52 PM
tracerbullet
Dec 6, 2012 2:49 PM
jpjcoll
Jul 30, 2011 4:05 PM
wildboy74ss
Apr 1, 2009 5:10 PM
