Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
lumina starter
Old Oct 17, 2012 | 6:20 PM
BethinOH's Avatar
Default lumina starter
1995 Lumina randomly won't start about 30% of the time. I was told it might have something to do with the theft deterrent system. What do I do to check that out before going on to more costly diagnostics?
Old Oct 17, 2012 | 6:37 PM
kevinkpk's Avatar
won't crank, I guess?
Old Oct 17, 2012 | 8:37 PM
typically, the contacts in the ignition cylinder wear and change the resistance of the pellet resistor in the key.
Does the security indicator come on when it no starts?
Old Dec 23, 2012 | 2:35 PM
GHOSTOWLGRID's Avatar
Have the security system checked like he said above.
That is if it has that.
Also, does it crank weak? Maybe the starter is going bad?
Check it out is my guess...
I know older cars the wire ends and wire terminals rust on the starter causing bad contacts, thus causing weak start or no start sometimes.
My Beretta I had half the starter go intermittent, causing weak start and sometimes no start, I'd have to sit there playing with it till it caught...lol
bavant
Jan 16, 2012 2:12 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
ekjetta98
Mar 31, 2008 5:56 PM
ekjetta98
Mar 31, 2008 4:53 PM
