Blazer Combining style with comfort, this all-new, sporty SUV is the epitome of adventure.
Chevrolet Blazer
Platform: C1XX
4x4 Hi gear
Old Apr 4, 2020 | 3:31 PM
Alejandro Maldonado's Avatar
Default 4x4 Hi gear
So I took my blazer out to some sand dunes ,and it was going fine , I got stuck and got pulled out , but afterwards High gear didn't want to engage, only 4x4 Low? What happened? Did something break ? Is it an expensive fix?
Old Apr 4, 2020 | 10:56 PM
manual shift tcase or electronic?
Old Apr 27, 2020 | 6:50 AM
its electronic
Old Apr 28, 2020 | 9:05 AM
inspect the tcase actuator motor connector wiring. if its intact; can you hear the motor move when the button is pressed? if you hear nothing check for power from the switch/module. you could also unplug the connector at the actuator and remove the actuator. then move the shift lever with a wrench...if the tcase goes into each mode...the tcase is mechanically is ok...the problem is with either the switch/module, actuator or wiring. the transfer case control module will set codes that can be read with a scan tool that accesses chassis codes.
Old Apr 28, 2020 | 9:52 AM
Thank you bro I've been tripping about it , ima check the codes as soon as I get out of work , and I'll keep you posted
'84K5HighRise
K5 Blazer
May 17, 2012 7:16 PM
goat147
Dec 5, 2010 8:18 PM
pleasureyou
K5 Blazer
Oct 23, 2010 8:33 PM
95BurbanTurbo
Apr 21, 2010 9:55 PM
chevygirl7
Jul 11, 2007 11:19 AM
