Blazer Combining style with comfort, this all-new, sporty SUV is the epitome of adventure.
Chevrolet Blazer
Platform: C1XX
Misfire
Old Dec 3, 2020 | 3:12 PM
  #11
Olandjonathan231's Avatar
Default Misfire
I did the wet test and there was no change in the psi. After doing a proper compression test and cylinders 4 and 6 were the same at 70 psi where the rest were 170 psi. Putting an air line on each cylinder 4 and 6 (1 at a time) and the air flows from one 4 to 6 and 6 to 4. Would this be a head gasket issue or would this be a cylinder head issue.
Old Dec 3, 2020 | 3:25 PM
  #12
kevinkpk's Avatar
The head will have to come off. I'd suggest having a valve job, heads either milled, or replaced. That I also would suggest both sides (heads).
Old Dec 4, 2020 | 10:49 PM
  #13
oilcanhenry's Avatar
170 PSI is great compression, but with two cylinders running at 60-70 PSI, you've got some work to do. No its not The head gasket. You have bad valves on #4 and #6.
Old Dec 8, 2020 | 11:48 AM
  #14
Default Misfire
Bad valves? This would mean I would have to replace the head correct?
Old Dec 8, 2020 | 12:45 PM
  #15
kevinkpk's Avatar
Probably have a valve job, or replace it, depending on how long you can be without the car.
Old Dec 13, 2020 | 8:21 PM
  #16
chevyboy@22's Avatar
Did you do a wet Psi readout
Invisions1
Dec 4, 2020 6:37 PM
tfulcher
Apr 27, 2014 12:08 PM
unkindshadow35
Feb 2, 2013 10:50 PM
cnterline
Feb 15, 2009 9:06 AM
