Spider injection
I'm here for the party
well its bad because if your issue is the injector then you have to replace the whole unit and not just one injector. do you have a code for just one cylinder or a general "misfire" code? if it specifies which cylinder try swapping plugs/wires around to see if the code follows or it might even be a poor spark plug/wire connection
Misfire on #4
