Chevrolet Malibu
2000 - Misfire and Injector Malfunction
Old Mar 12, 2010 | 10:24 PM
davescountry's Avatar
Default 2000 - Misfire and Injector Malfunction
This is a 2000 Chevy Malibu, 3.1 engine, aprox. 110,000 miles.
In the last 3 months I have done:
- replace fuel filter
- replace fuel pump
- replace lower intake gaskets
- re-wired IAT plug
- replaced IAT sensor
I am still getting OBD codes. Most of the time I am getting "Cylinder misfire on 6" and 'Injector Malfunction on 5." These are pretty intermitent and when I don't have them, the car runs great. When I do, it runs terrible and skips and bucks horrendously.
Sometimes, if I can get the rpms up, it smoothes out. Also, occaisonaly when it gets really bad, I get two more errors -- PO410 - Secondary Air Injection System Malfunction and PO412 - secondary air injection system switching valve a circuit malfunction.
I took it to a shop first. He said the misfire was due to a vacumn leak on the upper plenum. No mention of the injector problem. I then took it to the dealer. Eventually, he gave me the same diagnosis (after I told him what the first guy said) along with that I needed to change the injector on 5.
I did change the upper gaskets, and no improvement. I also checked the injector connections on 5 and made sure it was seated correctly. No improvement there.
I am skeptical on that diagnosis for two reasons. First, I couldn't find any vacumn leak when I sprayed the area with carb cleaner, and clearly replacing the gaskets didn't work. Second, I am hard pressed to believe that two unrelated problems (misfire and injector malfunction) keep happening at the exact same time over and over. I never get one without the other.
Just to remove variables, I did also replace the plug, plug wire, and swapped coils -- no improvement.
Any ideas on what could be happening here or what to try and test?
Old Dec 18, 2011 | 8:30 PM
Desta_1988's Avatar
Default Help
Did you ever figure out the problem? I'm having similar issues...
Old Dec 18, 2011 | 8:38 PM
coppola7's Avatar
I'm having same problem. I changed all plugs wires cap rotor (2003 silverado 4.3 L)
Any ideas?
Cookie4699
Dec 29, 2014 1:16 AM
BigRed922
Feb 14, 2014 10:19 AM
Codi Hammar
Sep 15, 2012 3:49 AM
vanfor7
Mar 31, 2012 5:46 PM
