2016 Camaro
Platform: F-Body & Zeta.
View Poll Results: Why no cluster lights no spark no fuel no starter operation all at once???
Airbag sensor not plugged in
0%
Needs gm flash bcm
0%
Theft deterant module triggered/need gm reset
0%
Fried bcm
0%
Ignition not properly wired
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
1995 Camaro stopped running all of a sudden
Old Nov 24, 2025 | 7:00 AM
Brandon Simpson's Avatar
Default 1995 Camaro stopped running all of a sudden
Not getting any cluster lights all others working properly, no fire, no injector operation, no fuel pump operation and no starter operation. Was my daily driver until the ignition felt like it was jammed out of nowhere so I replaced with a new chipped key and cylinder and no change then ordered another cluster swapped it out still no change. What am I over looking here? Please help she's been down 2yrs now and only has 9000miles on the rebuild...all suggestions welcome.
Old Nov 29, 2025 | 10:23 PM
Robby17's Avatar
Check all the fuses under the hood, especially the large ignition and ECM fuses. Also, check the fusible links at the battery.
Your symptoms point to a blown main fuse that kills power to the ignition, computers, and fuel pump. A fusible link is the most likely culprit.
Metalhead28147
Oct 4, 2025 2:58 PM
Brandon Simpson
Camaro
Jul 13, 2025 10:58 PM
onoahimahi
May 14, 2025 8:51 PM
aeauto
Camaro
Apr 22, 2017 7:58 AM
Knightwatchman
Camaro
Mar 21, 2010 5:48 PM
