2016 Camaro
Platform: F-Body & Zeta.
4.3 v6 into 1996 Camaro? Will it fit?
Old Mar 11, 2011 | 11:10 PM
PapaBurgundy7's Avatar
Default 4.3 v6 into 1996 Camaro? Will it fit?
The car has a 3.8 in it now but needs a new motor. I would like to know if the 4.3 would fit without any problem? ThAnks for looking.
Old Mar 11, 2011 | 11:35 PM
silverbirtchz71's Avatar
yes that car also came with a 5.7l v8 the 4.3 has the same basic width as the 5.7... will have to swap engine mounts and roll on
Old Apr 9, 2011 | 1:25 PM
Gorn's Avatar
No it will not fit. The V8 Camaro is designed around the LT1, THe LT1 does not have a distributer or a Thottle body like a 4.3. It is possible to make it fit but you better have a machine shop in the back yard for all the custom work you would have to do.
Old Jul 27, 2015 | 5:07 PM
robertbartley's Avatar
I have a 95 chevy Camaro with the 3.4 motor that is throttle body so I know it will fit
Old Mar 5, 2016 | 3:29 AM
Antwon Dreadsmystrenght Pewitte's Avatar
So you put a 4.3 in your camaro an what all you do 6152948974
Old May 31, 2016 | 6:01 PM
Gorn's Avatar
The 3.4 is a 60 deg V6 with multi point fuel injection. Yes like all fuel injected cars it has a throttle body on it but it not a throttle body injection system like the 4.3 has. You will not be putting a 4.3 in a 4th gen unless you are the kind of guy that can put v8 in a Chevette . Course if you are you would not e here asking if it is possible.
Old May 31, 2016 | 7:38 PM
bandit_601948's Avatar
it might fit and then it might not ! if you want my advice your better off to drop a 3800 v6 in it ! a 4.3 might fit but too much changing around ! a 3800 v6 would be a better idea !
2000 Tahoe
Jun 24, 2015 8:16 PM
eromore189
Dec 31, 2012 4:10 PM
stshadow
Apr 22, 2011 9:48 PM
CRFrizzell
Camaro
Nov 22, 2010 2:58 PM
