2016 Camaro
Platform: F-Body & Zeta.
81 Camaro Z28 350 no power (cam?)
Old Feb 4, 2009 | 12:08 AM
dred's Avatar
Default 81 Camaro Z28 350 no power (cam?)
Hi. I recently purchased a 81 Camaro z28 350 auto. I know these motors are famous for rounding the camshaft, it does have lifter noise on one bank and pops when given throttle, no power, all the spark plugs looked good when pulled except one that was black ( same side as lifter noise) dont want to replace cam if not needed. Any advice appreciated. Doug
Old Feb 10, 2009 | 12:18 AM
dred's Avatar
OK I pulled the pass side valve cover and found the loose rocker ( #2 cyl exhaust valve) almost no movement when cranking over, pushrod not bent, is it possible for just one lobe to round on the cam?
Old Feb 10, 2009 | 10:38 PM
dred's Avatar
This rocker is hardly moving, backed the nut off and held the end of the pushrod with my finger while turning over, very slight up and down movement,definitely cam rounded. going to put in a new one. Any suggestions? This car is completly stock except for dual exhaust so want a mild cam. Stock specs say lift .390/.410 duration 310/320.
Old Feb 11, 2009 | 1:38 PM
dred's Avatar
Thanks for the help. Doug
5.0stang
Jun 16, 2022 7:46 AM
e6bailey
Oct 17, 2007 2:38 PM
xlcrmoemoney
Jul 4, 2007 12:42 PM
dan7055
Camaro
Apr 8, 2007 4:58 AM
senor_coconut
Camaro
Oct 20, 2006 6:15 AM
