2016 Camaro
Platform: F-Body & Zeta.
91 hard to start when cold
Old Dec 15, 2006 | 12:29 PM
svnthvn's Avatar
Default 91 hard to start when cold
This is a RS 3.1 V6 that has had this problem but has gotten worse, always starts after being started till it gets cold. Entire distributor and cap, coil, map sensor, anti-knock sensor. plugs and wires have been replaced. No irregular ECM code, says all is fine. I installed a electric heater in the lower radiator hose that helps if the engine stays warm. The dealer has had and can not find the trouble. Is not equipped with a cold start valve so that is not it. Could the fuel pressure regulator be it, a lot of trouble to remove to find out.
Old Dec 16, 2006 | 6:52 AM
kcb37's Avatar
Default RE: 91 hard to start when cold
When you start it turn the key forward and wait for 2 or 3 seconds. That will let the fuel system prime. It should help some. Other than that I don't know what to tell you without taking a wild guess.
Old Dec 16, 2006 | 12:16 PM
svnthvn's Avatar
Thanks but I have even left the key at on position for 10 minutes before cranking. The battery is fairly new and will crank until dead but no start, the old battery was the same way. Someone told my key chip may be bad but why would the heater keeping the engine warm help?
Old Dec 16, 2006 | 12:34 PM
beckeruti's Avatar
maybe the ect ecngine coolant temp sensor is bad
and is saying the car is to cold
this is just a guess based on what u said about the engine heater thing
good luck
gjd99tahoe
Jun 10, 2018 11:11 AM
scottkern3
13
Jan 12, 2018 6:08 PM
izod
Feb 14, 2009 2:42 PM
EMK
Nov 11, 2007 10:36 PM
DominickSch
Sep 6, 2007 8:43 PM
