2016 Camaro
Platform: F-Body & Zeta.
96 ignition switch programming??
Old Mar 24, 2012 | 11:06 PM
Yvonne Nystrom Allen's Avatar
Default 96 ignition switch programming??
We just recently changed an ignition switch & cylinder on our 96 Z28. Alarm is still going off! The new ignition switch & cylinder is a AC Delco. It does not have the chip in the key like our old one did. Can someone pls helP??? Is there a way to manually program the new key??
Old Mar 25, 2012 | 3:29 PM
EinST's Avatar
Yours has the PASS-Key II a.k.a. VATS vehicle theft deterrent system. The lock cylinder has a two-wire electrical harness for the BCM to "read" the resistor pellet embedded in the key. I don't what you you mean by "does not have the chip in the key." Does the new key otherwise look like a genuine GM key or what?
boho115
Jul 10, 2013 7:15 PM
Truck Driver Bill
HHR
Aug 11, 2011 8:48 PM
leejosepho
Oct 26, 2009 10:51 PM
eddiek777
Oct 25, 2006 12:24 AM
RedE2go
Sep 14, 2006 2:30 AM
