2016 Camaro
Platform: F-Body & Zeta.
Making Power in my 1973 Camaro (HELP)
Old Nov 14, 2010 | 11:32 AM
oasis1242's Avatar
Default Making Power in my 1973 Camaro (HELP)
Hey everyone, im a bit of a noob so bare with me. I have a 73' z28 and im looking for ways to boost up the performance. My main goal is to get the 0-60 in at least the low 5's. What do you recommend i do? If it happens that i need an engine and tranny swap please tell me which ones are best value and additional parts needed for the swap as well as prices. Any help would be greatly appreciated, thanks.
Old Nov 15, 2010 | 2:44 AM
Impala03dj's Avatar
Exhaust is one. Piece it together. I got a Magnaflow muffler for sale?
Old Nov 15, 2010 | 12:01 PM
gotstylez's Avatar
a exhaust..a cam..dfferent intake and carb.....if money isnt a issue bore it out and get bigger pistons and different heads maybe a supercharger... or turbo?
Old Dec 5, 2010 | 3:59 PM
BNRacing's Avatar
You don't say what motor is in it, so I'll assume it's a 350ci. Heads, Cam, intake, good carb, good headers will help. The biggest thing for a quick 0-60 time will be a good rear end with a good gear ratio, like a 3.73 or 4.11.
Old Dec 5, 2010 | 4:45 PM
2wd-K5's Avatar
yea 350 in a 73 z28, everything these guys have said will do what you want, if you are a noob at this i would sugest getting an edelbrock performance kit, one that comes with heads, cam,intake and carb this way all the parts are matched to compliment each other, different cams and intakes are for diferent rpm's so if not done right your could end up with a dog, you will need to take the trans into a rebuilder or you could order one from poenix trans, they are the cheapest i have seen with the best warranty, then your rearend will need work, currie is one of the best companies for that and they have a high volume so prices are decent,
just remember the rule: fast : cheap :reliable- pick 2
Old Dec 6, 2010 | 5:06 PM
oasis1242's Avatar
Thank you so much to all of you. Your really helpful.
598 FAT RAT
Aug 9, 2015 9:37 AM
ccnchevroletforum
Jun 27, 2012 11:28 AM
pjp98z
Feb 21, 2012 5:27 PM
Kevie
Camaro
Sep 30, 2009 8:02 PM
