2016 Camaro
Platform: F-Body & Zeta.
Th350 trans lines
Old Aug 19, 2019 | 10:41 AM
81Z28's Avatar
Default Th350 trans lines
Have a new 350 trans. Installing a trans cooler. Which line on the trans in the return line?. Top or bottom?.
Thanks
Old Aug 19, 2019 | 10:55 AM
kevinkpk's Avatar
I don't think it matters
Old Aug 19, 2019 | 3:00 PM
81Z28's Avatar
According to articles in the past you would want fluid to go thru the extra cooler after it passes thru the radiator so you don't cool it down first
then heat it up as it goes thru the radiator then back to the trans.
Old Aug 19, 2019 | 3:54 PM
kevinkpk's Avatar
Just bypass the radiator. Shouldn't matter which way the fluid flows. Or put the radiator, external cooler in series. Route the top line from the radiator to the external cooler, then back to the transmission.
Old Aug 19, 2019 | 4:00 PM
kevinkpk's Avatar
Old Aug 20, 2019 | 7:22 AM
81Z28's Avatar
Like you said i was going to put them in series. The top line is what i needed without firing her up & seeing which line pukes.
Thanks
gmtruckman
Mar 12, 2019 12:21 AM
Trainwreck68
Sep 2, 2014 4:23 AM
funnnyfarm
Jun 26, 2013 11:42 PM
rtarb41323
Apr 2, 2012 8:05 PM
T_Jeffreys
Oct 11, 2007 6:32 AM
