Tires Rubbing
<hr style="color:#eeeeee; background-color:#eeeeee" size="1"> Does anyone hear some rubbing when making tight turns at slow speeds?
I park in a garage with epoxy floors and mostly notice when making the turn out sounds like tires are rubbing the inner well!
No noise when wheels are straight.
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> lutherbeau,I'm sorry you are experiencing this issue. I would be happy to check my resources for any known related issues. Please PM me your VIN so I may proceed.
I look forward to your reply.
Louis
GM Customer Service
My rear tires rubs the body of my car. How can I raise it up to prevent the rubbing?
I bought a rim that is 3" bigger that the factory and now when I carry passengers or small load in the car, my tires rubs. Do I need lowering spring ( I do not want to lower the car for sure), coilover, or shock. Please tell me why you chose your choice. I do not want the factory parts but I don't mind if that is the only choice I have. I would appreciate it if you can help.
