2016 Camaro
Platform: F-Body & Zeta.
Tires Rubbing
Old Nov 8, 2012 | 1:55 AM
lutherbeau's Avatar
Default Tires Rubbing
<hr style="color:#eeeeee; background-color:#eeeeee" size="1"> Does anyone hear some rubbing when making tight turns at slow speeds?
I park in a garage with epoxy floors and mostly notice when making the turn out sounds like tires are rubbing the inner well!
No noise when wheels are straight.
Old Nov 9, 2012 | 1:19 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> lutherbeau,
I'm sorry you are experiencing this issue. I would be happy to check my resources for any known related issues. Please PM me your VIN so I may proceed.
I look forward to your reply.
Louis
GM Customer Service
Old Nov 9, 2012 | 1:41 PM
kevinkpk's Avatar
If the tire(s) are rubbing, inspect the inner wheel well for rub marks. If so, have you altered the front wheels?
Old Nov 23, 2012 | 2:30 AM
devid67's Avatar
My rear tires rubs the body of my car. How can I raise it up to prevent the rubbing?
I bought a rim that is 3" bigger that the factory and now when I carry passengers or small load in the car, my tires rubs. Do I need lowering spring ( I do not want to lower the car for sure), coilover, or shock. Please tell me why you chose your choice. I do not want the factory parts but I don't mind if that is the only choice I have. I would appreciate it if you can help.
Old Nov 30, 2012 | 6:12 PM
Indio's Avatar
It only happens in your garage though?
Old Nov 30, 2012 | 6:34 PM
67Motorcat's Avatar
What year camaro?
What size tires?
What size wheels and offsets?
No way to answer with out knowing more info
Old Feb 2, 2014 | 10:43 AM
eugene_leduc's Avatar
The noise only occurs when your taking turns? It could be the CV joint.
Old Mar 4, 2014 | 11:57 PM
75CamaroLT's Avatar
Have you tried rolling the fenders? If you roll the lip of the fenders than that usually helps with rubbing.
jeffshelton12
Jan 5, 2026 5:15 AM
H510
Dec 27, 2014 11:43 PM
JHarris8732
Nov 10, 2011 11:25 AM
fasteddie1991
May 21, 2007 8:02 PM
swatson1
Oct 18, 2006 1:09 PM
