2016 Camaro
Platform: F-Body & Zeta.
Wont start.
Old Dec 6, 2007 | 8:10 PM
91blubyou's Avatar
Default Wont start.
First of all thak god for sights like this. Now on to my proble, I have a1991 RS Camaro, I was driving to work and the car just died on me ,half a tank of gas and late for work. After replacing the battery, coil , ignition module, i still cant get any spark. ant help would be greatly appriciated so that i can get my blu babe back on the road and blow right by them fords.
Old Dec 6, 2007 | 10:34 PM
engine2's Avatar
Default RE: Wont start.
Welcome to the forum.
I would check your spark plug wires
Old Dec 7, 2007 | 7:38 PM
aj_wicked13's Avatar
are you getting power to your coil/dist.? get a meter or test light and with the ingition on make sure there is power going to the battery side of the coil... if no power i would start looking back into your wiring(fuses, ignition switch ect.)
if you are getting power to the coil/dist. I would check the dist itself. there is a pickup on the distrubitor that sends a signal to the Control modual and tells it when to fire the coil. if this pickup is bad it never tells the controll modual to fire. I believe the pickup on that car is only like 20 bucks. a shop manual should tell you how to check it (but i believe as the distrubitor shaft turns it "trips" causing continuty between the two leads coming off of the pickup itself.) Again I would check with a shop manual on how to check that as im not 100% sure about it.
Tootallmech
Aug 7, 2023 11:49 AM
sleepingciv
Jul 25, 2020 1:03 PM
bracca
Jul 12, 2009 6:14 PM
wildboy74ss
Apr 1, 2009 5:10 PM
