Platform: B-Body
305 sbc AIR tubes removal
Old Aug 6, 2019 | 6:20 AM
Benza's Avatar
Default 305 sbc AIR tubes removal
Dear all,
Is it possible to take out only AIR tubes to headers from "smog" pump on 305 small block chevy, plug the holes on headers of course... Maybe somehow "bypassed AIR pump" ?
Thanks
B.
Old Aug 6, 2019 | 4:52 PM
oilcanhenry's Avatar
Originally Posted by Benza
Dear all,
Thanks
B.
Yeap ! Why not get rid of the pump too? Sure you'll need a new belt, but getting rid of SMOG pumps make me feel very good.
Old Aug 6, 2019 | 11:45 PM
Benza's Avatar
And what about some possible problems? Backfiring for instance...
Old Aug 7, 2019 | 8:26 AM
I never encountered that issue. First A.I.R. pump I chucked in the garbage was the one on my fathers old Chevrolet 1969 C-60 366 cubic inch motor. It DID backfire with the smog pump installed (too many smog pumps in fact as they did last long in dust) all the time, It hardly ever backfired after that. The AIR Diverter Valve was always going bad too on that old truck.Spent lots of money on that system before I pulled it.
Old Aug 8, 2019 | 12:24 AM
Benza's Avatar
Awesome... N what about harness connector? Just unplug it and leave it be? Can't be a problem with ECM?
Old Aug 9, 2019 | 2:46 PM
Never pulled an A.I.R. pump with ECM wires, to be honest. You might try pulling that off first to see if any codes show, however. If not, I'd yank the thing off. If so there may be a way to bypass it. Maybe leave the plug receptical on, zip-tie it down and pull the air pump off.
Old Aug 9, 2019 | 4:16 PM
Benza's Avatar
Yeah, we shall see... maybe some type of resistor can solve it.. I guess I don't need that smog pump elimination pulley cause that piece of garbage has its own separate belt...
Old Aug 9, 2019 | 4:30 PM
Benza's Avatar
I found somewhere on the other forum that "early" models with OBD1 (which is mine) don't throw a code.. but those with OBD2 actually did. But as You and I said.. The easiest way is just to try unplug it.. I'll try that tomorrow..
Old Aug 11, 2019 | 1:13 PM
Let me know if it works. Looks like you got lucky with an old Vee belt turning the A.I.R. pump. Won't even need to buy a shorter serpentine belt!!
Old Aug 11, 2019 | 2:49 PM
Benza's Avatar
Yeah, I'm so glad I don't need to deal with that delete pulley and new belt... So.. I unplugged those two connectors today and It doesn't throw any codes, so i guess I'm lucky two times!
