Platform: B-Body
Cop Car Tranny
Old Aug 23, 2011 | 8:18 PM
rickyt49's Avatar
Default Cop Car Tranny
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I have a 1994 cop car with the LT-1. In a slight pull the converter, (at least I think it's the converter) "hunts". By that I mean it locks up, then out, then up, then out, etc. It may possibly be going into & out of O/D. Any tips? - Thanks – Rick
Old Aug 25, 2011 | 10:30 AM
RacerX's Avatar
try it in 3rd, OD Lockout.
most likely wack torque converter lock up solenoid. 4L60E. Its in the case accessible by the front of the oil pan. The new part requires you to splice the new one onto the old harness. Or you can go without it. You will have OD, fuel efficiency, but not maximal coupling of the converter.
Old Aug 26, 2011 | 7:30 AM
rickyt49's Avatar
Thanx Racer. That makes sense. I have solder shrink & 50 yrs. Of electrical experience, so cutting in the new one should be no problem. - Rick
54Delivery
Feb 15, 2015 3:55 PM
Gelidus
Jan 9, 2014 4:14 PM
coley86
Oct 23, 2012 9:14 PM
rickyt49
Corvette
Aug 28, 2011 10:26 PM
