Platform: B-Body
engine seized, any tips and tricks?
Old May 24, 2011 | 4:22 PM
macruadhi's Avatar
Default engine seized, any tips and tricks?
I have a 91 Caprice that has been sitting about 2 years. Now that I've fixed what was wrong with it, it seems the engine has seized up. I had it turning over less than six months ago. I've read other forums, used the recommended oils in each cylinder, now I am waiting for it to penetrate. Other than the crank bolt, any other ideas for getting it broken loose?
Old May 24, 2011 | 8:43 PM
old dog's Avatar
Default siezed
get a fly wheel turner and work it back and forth ,some times a little atf in the cylinders helps .
http://www.lislecorp.com/divisions/p...n=1&category=6
Old May 25, 2011 | 12:29 PM
Reynolds357's Avatar
Fill the entire engine up with mineral spirits and let it set for a few days. By fill it up, I mean fill up the spark plug holes until it runs out and fill up the engine until it runs out the oil fill hole, and keep topping it off.
Once it frees, do not turn it anymore. Mineral spirts has almost no lubricating properties.
TahoeMatt
Feb 20, 2013 6:29 PM
88 4X4Dumpster
Mar 28, 2012 7:21 PM
Doug Mercer
Feb 9, 2011 9:14 PM
select605
Cobalt
Apr 13, 2008 3:49 PM
triple_b
Dec 2, 2006 3:22 PM
