Platform: B-Body
Headlight problem
Old January 9th, 2014, 6:29 PM
oldfrog's Avatar
Default Headlight problem
Hello all,
On my 1988 Chevy Caprice wagon, the outside low beam headlights go
out when I turn on the highbeams...can someone tell me a place to start ?
Also, if someone suggest a headlight relay...where is it located ?
Thank you
Old January 10th, 2014, 7:04 AM
200OZ's Avatar
That year has the one piece molded plastic head lights I believe, that's normal for GM's of that era, even up to some current models.
Painless Wiring has a "fix" for that. Try Jeg's or Summit Racing.
Old January 10th, 2014, 2:25 PM
oldfrog's Avatar
@ 200OZ,
You may be right about how it works...I looked at the bulb plugs today and the low beam only has two wires in it as well as the high beam, I
just never noticed the low beams going out (off) when the high beams
were turned on. And yes, you were right about the one piece molded
headlight, but mine are real glass.
Thank you.
Old January 15th, 2014, 4:33 PM
Blaidd Drwg's Avatar
My 90 Caprice 9C1 was like that, I used the painless style upgrade, but I got mine from LMC truck for the Chevy trucks, same hook ups and a less money. Surprised at how much you can see when you have all four of those babies running.
garyv990
February 11th, 2015 9:52 PM
flynnstone_45
Astro
February 10th, 2007 10:46 AM
mikestopford
September 2nd, 2006 6:34 PM
Schlickster
July 25th, 2006 2:36 PM
jorgie5150
May 10th, 2006 6:56 AM
Quick Reply: Headlight problem
