Captiva The Captiva has been sold worldwide since 2006 and now comes to the US to replace the Saturn Vue
Chevy Captiva
Platform: Theta
2014 Chevy Captiva coolant leak
Old Jun 23, 2024 | 9:11 PM
delias's Avatar
Default 2014 Chevy Captiva coolant leak
We have a 2014 Chevy caprice sport and have been dealing with a coolant leak. We have checked all the hoses and there’s no rips or holes. No cracks in the reservoir. Just replaced the water pump. Going through bottles of coolant like crazy. In AZ so temperature is getting very high already and have had the car overheat twice. Any suggestions?
Old Jun 23, 2024 | 10:48 PM
Rednucleus's Avatar
Are you seeing puddles on the ground?
Old Jun 23, 2024 | 11:00 PM
delias's Avatar
we have noticed a few after shutting the car off. Not immediately though
Old Jun 24, 2024 | 7:11 AM
martinef1963's Avatar
That is a good sign. At least you can account for the leak. Anyway, might as well check your oil dip stick to rule out a cracked head.
Old Jun 24, 2024 | 9:49 AM
delias's Avatar
man oil change was just done on the car about 3 weeks ago. Didn’t look like there was any coolant leaking into the oil. No clear liquid came out
Old Jun 24, 2024 | 10:19 AM
either get yourself a radiator pressure tester or take it to your mechanic. It’s a piece of equipment you screw onto your radiator reservoir and pump pressure into the cooling system. If you have a cracked hose or leaking radiator you should be able to see it. Also keep an eye on your heater core. Hope this helps.
Dunmore1$
Cruze
Mar 30, 2024 3:24 PM
dccosta73
Captiva
Dec 23, 2023 6:41 PM
BooBoo1965
Aug 23, 2021 6:01 AM
cruze_lova
Cruze
Jun 6, 2021 11:42 AM
gixxerscott
Jan 27, 2017 12:56 AM
