Platform: J-body
03 Cav Noise issues from Rotors?
Old Nov 30, 2007 | 12:49 AM
sociald13's Avatar
Default 03 Cav Noise issues from Rotors?
HI Gang
i've got an 03 cav.
When i drive, i hear a grinding noise at the same point, which sounds like its coming from the rotors. The faster i go, the faster the noise/revolutions happen. Seems to be coming from the drivers front wheels.
I went on vacation, let the car sit and when i came back, the noise started.
Thoughts?
Old Nov 30, 2007 | 11:57 AM
ruffrider285's Avatar
Default RE: 03 Cav Noise issues from Rotors?
its deff your rotors, if you change the rotors make sure you changed the pads to. I would recommend getting ceramic pads put on to, if you get semi metallic they will sweak like crazy.
Old Dec 4, 2007 | 7:09 PM
cavyone's Avatar
I aggree with ruffrider about 3 months ago i had the same problem. I changed out my pads and rotors and all the noise went away.
Old Dec 5, 2007 | 5:19 PM
waltd140's Avatar
Or bearings are going south. The caliper might be sticking which would makeyou notice more brake dust on the rim then normal. That's usually a sign of a sticky caliper. But don't forget the bearings as well. Might be a good idea to take the tire off & have a look.
Walter
boss302beav
Oct 8, 2014 8:53 PM
oompaloompa7
Jan 8, 2010 2:34 PM
kat 135
Jun 5, 2008 12:50 PM
mandiebj
Feb 9, 2006 10:52 AM
ice777
Uplander
May 8, 2005 10:16 PM
