Platform: J-body
99 Cav won't start. Loud grinding noise
Old Jan 2, 2010 | 1:52 PM
oompaloompa7's Avatar
Default 99 Cav won't start. Loud grinding noise
So as of the 31st, my car started to make a weird noise when I turned it on. First incident, I turned it and it made that loud scratchy noise that a car makes when it's already on and you turn the ignition in error. Car started though. Few hours later when I go turn it on again, it's dead. We charged it and it turned on ok. I tested it a few hours later again and it would make a weird clacking/ grinding noise and not turn on at all. Left it alone on Friday since I didn't need to go out.
Today I tried charging it again with the jumper cables and that wouldn't work. It makes a horribly loud cranking noise. My bf thinks it's the engine. I've experienced alternator and battery problems on that car a lot and I've NEVER heard a noise like that. I don't think it's the battery because my radio, lights, car alarm, and dashboard all work.
I'm thinking of having it towed tomorrow to a mechanic so they can determine what's wrong. I'm thinking if it's something that's going to be too costly, I might just get a new car. Too many little things are starting to act up and it's putting a nice hole in my pocket.
Now, have any of you experienced any of this and if so, what was wrong with it?
Old Jan 7, 2010 | 1:55 AM
todds96cav's Avatar
Sounds like a bad starter.
Old Jan 8, 2010 | 2:34 PM
jfazio5188's Avatar
It really sounds like a starter issue. Which is not to costly at all.
davidsonw88
Mar 8, 2014 11:39 AM
bradm
May 21, 2013 1:06 PM
ph4ze
Aug 4, 2012 2:17 PM
jonathan94
Sep 9, 2007 8:14 AM
jbeebe@temple.edu
May 5, 2007 6:08 PM
