Platform: J-body
03 Ecotech water in oil!
Old Aug 11, 2013 | 11:07 PM
jbarnes's Avatar
Default 03 Ecotech water in oil!
Does anyone know if a frontal impact that puts pressure to the plastic intake can cause a water leak into the engine?
Replace core support, rad, a/c condenser etc and after one day of driving, overheated and I found the engine oil to be milky (water). Are there water passages in the intake? any info is appreciated.
Old Aug 12, 2013 | 7:34 AM
maybe a cooling system pressure test would be the next step to isolate the problem.
Old Aug 16, 2013 | 3:06 PM
Ihavenoclue's Avatar
no way.... that is not posible. I have removed several intakes on ecotecs and they dont have any connexion with the cooling system.... if the car overheated is more likely that you have a bad head gasket. Autozone has a tester on their loan-a-tools program OEM/Block Tester (27145) | Block Tester | AutoZone.com_ Good luck.
Old Aug 17, 2013 | 5:15 AM
Headache Ball's Avatar
Need more info... How bad was the front impact? Any motor mounts broken? Was your cooling fan running? Was the cooling system purged of all air before you drove it?
ekwbtx66
Feb 25, 2010 4:35 AM
cavy2002
Oct 12, 2008 11:30 AM
lgibbs27
Mar 5, 2008 8:01 PM
mach1misfit
Feb 12, 2007 12:39 AM
