Platform: J-body
1986 Cavalier CS Intermittent No Start
Old Jan 28, 2019 | 5:50 PM
hgw53t's Avatar
Default 1986 Cavalier CS Intermittent No Start
The engine is a 2.0- Liter 4-cylinder. It may not start if engine compartment is damp. I let it sit for a few hours & it will start & run well. It is definitely a no spark condition & I believe it is an electrical bulk head wiring connector problem. I believe it is in the right connector at the fire wall of the car. I am trying to separate the male from female connector. I have removed it from firewall and tried to separate halves with no luck. Does anyone have ANY suggestions on that? I can provide more details & pictures of it.
Right side electrical bulkhead connector at firewall
Right side bulkhead connector at firewall
Note: RTV clear silicone applied over wiring which did not help to waterproof
Old Dec 22, 2019 | 8:33 AM
hgw53t's Avatar
I am replying to anyone out there who has or had this problem. The problem was the ignition coil. It was getting damp or wet when this would happen. The way I know that the problem has been recedtified is that I R&R the coil with a new one & sprayed a stream of water on it when engine was running & engine did not stall out. Engine would stall out everytime BEFORE I replaced ignition coil. I believe what caused the coil to fail is when I would clean the engine & engine oil and dust and dirt would get on the coil and would "intensify" the problem when it would rain the night before .... The problem was a combination of dampness & engine oil, dust, dirt, etc. getting on the coil.
I believe the answer to any future problem with that is to move the coil to another location. Anyone know of a kit or have any info on that?
hgw53t
Jan 27, 2019 1:55 PM
Adam013085
Nov 30, 2012 2:39 PM
Hal's place
Oct 12, 2011 10:28 PM
ferncalderon
Jun 6, 2010 1:08 PM
5trucks
Dec 26, 2008 8:08 PM
