Platform: J-body
1998 Z24 Cavalier Shifting Problems
Old Apr 5, 2010 | 8:57 PM
  #11
Hobbydad's Avatar
First off there is nothing free in this world anymore. I'm not sure where you can get it done free at. Second I thought this was a DIY Forum, that information doesn't get me anything. A transmission shop will charge at leat 1800.00 for a rebuild and they don't do anymore than they have to. I talked with my wifes cousins husband and he told me a lot more than I ever got here.
Thanks Anyway! Bone up on the DIY!
Old Apr 6, 2010 | 3:18 AM
  #12
Roanoker494's Avatar
Are you a computer, or do you rebuild transmissions? Cause you need to have the transmission scanned. Might cost money but if there is an internal sensor problem you will never figure it out without someone with the right knowledge. Want a DIY approach, thats fine. Go to the salvage yard and buy a transmission with a warranty, of course that is not going to help if it is a computer issue. I don't know where you live but all the transmission shops around here have a free check-up offer. You ask for advice then pull out this bull crap when someone tries to offer sound advice. If you replaced the TPS and think it may still be bad, then take it back and get it replaced. There is no way to clear the trouble codes from the computer without a proper scanner. The scanner at the parts store will not pull transmission codes.
Enjoy your day
Old Apr 6, 2010 | 3:24 AM
  #13
Also. If you have to ask someone what you should do with the voltage meter then you are not the person who should be shoving metal probes into electrical connectors. Put those probes in the wrong place and cause a short and there goes the PCM, which is the powertrain control module.
Again, enjoy your day
Old May 20, 2010 | 9:45 AM
  #14
vortec02's Avatar
I also wanted to add, I have a check engine light on and dash says ETS Off.
Thanks,
Hobbydad
this happend in my 99 z check all your fuses the trans is in safe mode detecting something is wrong turned out it was the ERLS fuse in the fusebox located driver side of the dash it the fuse is good it may be a bad speed sensor hope i can be of help
Old May 21, 2010 | 7:51 PM
  #15
zr-2 blazer's Avatar
Hobbydad well is your gfs whatever is so good at dognositing problems without even usuing a computer why are you even on here? and why do you ask us for opioions and to give you answers. If he knows so much go to him, go ask him. This isnt the place for you. sorry.
perry2326
Oct 19, 2013 10:25 PM
mikestoyshop
Jul 9, 2013 12:40 AM
thunderrace
Jul 7, 2011 12:49 PM
nwohiochevyguy
Apr 27, 2010 12:58 PM
EricaG
Jan 31, 2010 12:09 AM
