2000 Cavalier Won't Start
I bought this car 3 weeks ago and it worked great, til I was trying to find why power window on drivers side wouldn't work. Found out it is the window motor and have bought that. Somehow during the examination process there was an electrical hiccup and the car won't start now. The instrument panel lights up, then everything except the check engine, battery, oil and airbag lights go out. Power windows, locks, radio and interior lights all function. When I turn key on the starter dosn't even click. The battery has been tested, is good and fully charged. All fuses checked and good. New ignition switch was installed. Wiring in column verified and intact. No sticking or jamming of key cylinder. I attempted Passlock Bypass, based on others experience, with no changes occuring. Used OBD II reader and it came back saying "Link error". The battery cables appear intact, all bolts secure and I cleaned all connections. I am learning to do this on my own, as my dad was my mechanic and he passed away last year. Any suggestions, or previous experiences you share, will be greatly appreciated.
Although this may or may not be your no-start problem, check your fuses again. The one for the cigarette lighter/accessory plug is what powers the OBD terminal, and lack of power is likely why you're getting a communication error. Does your car have more than one fuse block, and perhaps you missed it?
Jack the car up. Use a screwdriver on the starter to bypass the ignition switch.
Just connect the big copper post on the solenoid to the small post on the solenoid. See if you can at least make the starter crank. If not, check the ground cable on the block. If it cranks, start following the small wire to see if it's open anywhere. Try to get a diagram to see if it may be the nuetral safety switch. If it doesn't crank and the battery voltage can be measured with a voltmeter on the solenoid, then the starter is bad.
Oldchevy & Camaro 69 Thank you for your suggestions! Did recheck all wires, connections and both fuse blocks, but only thing I see wrong is the battery end of positive cable connector has some metal wear on the contact surface. The silver metal "crumbled" away so copper colored under layer is exposed. I used a brass brush and cleaned the metal dust away, but it didn't make a difference. Could the the connector maybe be compromised and need replaced?
Hi Camaro 69, workaholic and oldchevy. Just wanted to give a shout out to you 3, with thanks for your suggestions last week! It turned out the issue was a starter relay that didn't exist in the Chilton diagram and repair manual, or in the parts listing at NAPA. I ended up taking it to the retired mechanic that has serviced it for previous owner the past 7 years. He went thru what I had ruled out on it, then spent another little bit checking it and discovered the ghost relay and replaced it. She works beautiful again. He replaced the dead drivers power window motor for me too. After the no start issue happened I was done for this month! =P
