2001 cav no start
hey guys i have a 01 chevy cavalier that does not start i have fuel i have spark i have compression i even removed the 02 sensor thinking not enough back pressure i have injector pulse eveything has anybody ever run into this problem its a 01 cavalier 2.2 engine single camthere is communication with pcm and scanner as ell any input would be greatly appriciated
If you have compression, a spark, fuel, and backpressure, it'll start assuming your starterworks and the battery is charged.
Have you checked the throttle body and PCV valve for blockages?
i hooked up the scanner and the crank sensor seems to be working fine timing i havent checked that is my next step im going to start removing the timing cover tomorrow but if it as the crank sensor was bad oulnt i have no spark and i do have spark
gargamel343
March 14th, 2007 12:58 PM
