Platform: J-body
2001 cav no start
Old Nov 3, 2007 | 4:36 PM
mauri197's Avatar
Default 2001 cav no start
hey guys i have a 01 chevy cavalier that does not start i have fuel i have spark i have compression i even removed the 02 sensor thinking not enough back pressure i have injector pulse eveything has anybody ever run into this problem its a 01 cavalier 2.2 engine single camthere is communication with pcm and scanner as ell any input would be greatly appriciated
Old Nov 3, 2007 | 5:45 PM
EvansBlue's Avatar
Default RE: 2001 cav no start
If you have compression, a spark, fuel, and backpressure, it'll start assuming your starterworks and the battery is charged.
Have you checked the throttle body and PCV valve for blockages?
Old Nov 3, 2007 | 6:41 PM
DAVID L. PAUL's Avatar
HOW ABOUT CORRECT TIMEING
Old Nov 3, 2007 | 8:31 PM
Scoper50's Avatar
Given the information you provided, I'd seriously lean toward the Crackshaft Position sensor.
Old Nov 3, 2007 | 9:06 PM
mauri197's Avatar
i hooked up the scanner and the crank sensor seems to be working fine timing i havent checked that is my next step im going to start removing the timing cover tomorrow but if it as the crank sensor was bad oulnt i have no spark and i do have spark
Old Nov 3, 2007 | 10:18 PM
EvansBlue's Avatar
I forgot to mention timing. Yes if youre sparking late, thats def. an issue.
KunoCorp
Jan 24, 2011 2:19 PM
H8breedgirl
Mar 29, 2009 5:41 PM
sebsurf715
Sep 19, 2008 1:03 AM
gargamel343
Mar 14, 2007 12:58 PM
jnkakron
Oct 16, 2006 4:55 PM
