Platform: J-body
2002 cavalier
Old February 23rd, 2012, 5:43 PM
lauri's Avatar
Red face 2002 cavalier
I have a 2002 cavalier with an air condition problem. It was working fine and then started to only produce cold air when I am easing off on the gas,as soon as i step on the gas again it stops blowing cold. The engine and temperature remains normal.Any suggestions would be appreciated
Old February 25th, 2012, 2:26 PM
cleveland63b's Avatar
probably a low charge you'll probably have to take it to a shop unless you have access to a set of gauges or recovery machine
Old February 26th, 2012, 8:06 AM
lauri's Avatar
Default 2002 cavalier air condition problem
Thank you for your reply,I have gauges and have checked the system and the charge is where it should be.
Old February 26th, 2012, 11:00 AM
might check the air gap on the clutch and try to make sure that its staying engaged, what were the pressures you had on your gauges?
Old February 26th, 2012, 2:18 PM
lauri's Avatar
Default 2002 cavalier air condition problems
I can't recall the gauge readings as it was done 6 Mos. ago.Seeing as the unit delivers cold air when I ease off on the gas I suspect a lack of vacuum some where but I do not hear any hissing sound of leaking vacuum.If the temp. here gets above the freezing mark I will check with the gauge again.
Old February 28th, 2012, 9:03 PM
was the problem happening then? could have developed a leak. Does the airflow change modes at all or just change temperature? I personally haven't had to dig too far into the evac systems on cavaliers they just usually had a leak somewhere, have replaced a fair amount of compressors.
Old February 29th, 2012, 7:45 AM
lauri's Avatar
The modes stay the same on this vehicle. I had a Ford F150 that started to only blow cold air when i stepped on the gas and it would change from the vents to the defroster but this cavalier stays where it is set.
Nicole
December 28th, 2017 7:21 PM
srt4_night_rider
April 2nd, 2006 7:18 PM
snubber
November 3rd, 2005 5:09 PM
Clarissa
August 5th, 2005 12:47 AM
Quick Reply: 2002 cavalier
