Platform: J-body
2002 Chevy Cavalier A/C not working
Old Jul 5, 2018 | 8:40 PM
cbharless78's Avatar
Default 2002 Chevy Cavalier A/C not working
2002 cavalier LS 2.2L automatic
the air conditioner is not working. i have taken the cover off the relay and manually closed it which causes the compressor to kick on and ice cold air to blow. i have swapped relays but the same issue occurs.
Old Jul 5, 2018 | 10:08 PM
is the refrigerant level low?
Old Jul 6, 2018 | 5:51 AM
I believe levels are good, I will double check it this evening
Old Jul 9, 2018 | 6:49 AM
oilcanhenry's Avatar
How can you know the pressures are good unless you test them?
Old Jul 9, 2018 | 11:00 AM
Yes i agree. That is how we found out it was not working, I personally didn't check them because I don't know how but a family member who does minor service and has the equipment is the one who said everything was reading correctly.
Old Jul 9, 2018 | 11:21 PM
best bet if you have access to a machine is to recover the system...they you know with 100% accuracy the charge level....looking at pressures on a guage isn't the best method
Old Jul 10, 2018 | 4:57 AM
I will definitely keep that in mind when I get a chance to mess with it again
