Platform: J-body
2002 chevy cavi fuel issues
Old Aug 20, 2020 | 4:38 PM
  #11
Jiyu's Avatar
Bad grounds can make modern cars do weird things. To eliminate this possibility remove all ground straps, clean to bare metal and re-install. Do the same with battery connections.
With that many miles the rings/valves are probably worn - heavier wt oil can help with that. If you recently changed the oil, maybe try adding a pint of STP or other viscosity-booster. In summer, the added heat will exacerbate this issue.
A compression check will tell you how worn the engine is. If the comp is low, first step would be to pull the head and do a valve job. Second step would be to find a low-mileage engine from a wreck....
Joe JR
Aug 3, 2023 11:58 AM
Froggtog
Jul 21, 2014 7:40 AM
chaney6366
Apr 14, 2012 12:08 AM
wvsummertimelovenow
Oct 12, 2007 12:42 PM
dave509
Aug 21, 2006 11:52 AM
