Platform: J-body
2004 Cavalier 2.2 starting issues
Old Jul 28, 2020 | 3:47 AM
tim_james2's Avatar
Default 2004 Cavalier 2.2 starting issues
I just got started working on repairing this vehicle for a friend. It started with the clutch did not work, so I repaired it and moved on to an electric demon. The vehicle has drawn the battery dead so I replaced the battery. The starter was bad and also replaced. Now I have gotten to attempting to start it. When I turn on the ignition switch all the indicator lights on the dash light up, when I turn the key to the start position everything shuts off and the engine does nothing. Turn the key off and back on and all the lights are back on and the situation continues. I have replaced the electric ignition switch and today a new clutch pedal switch will be installed I have also cleaned every ground that I can locate. I am at a loss as to what to check next. Oh yes, if I leave the new battery connected there is a constant draw on it. I sure hope someone chimes in and gives me a hand with this problem.
Old Jul 31, 2020 | 11:32 PM
Jiyu's Avatar
Do a search on YT for 'parasitic draw test'. There's a number of vids on the subject.
Old Jul 31, 2020 | 11:33 PM
Jiyu's Avatar
Do a YT search for 'parasitic draw test.' There's a number of good vids on the subject.
Are you sure the security system isn't preventing the car from starting. There's a procedure for re-arming the anti-theft. This might do it: Try to start car, when it doesn't start, leave the ignition ON until the anti-theft light goes out (usually takes about 10 minutes). Repeat that procedure three times and that will disarm the anti-theft.
Buy a cheap scan tool, or have find an auto parts store that'll read the codes for you for free (many do).
tim_james2
Jul 27, 2020 6:27 PM
RonaldoT
Mar 27, 2018 3:00 PM
impalafirst
Apr 9, 2011 12:40 PM
CHEVYCHASE94
Jul 30, 2007 9:20 AM
juggalo17
Dec 21, 2006 7:37 AM
