Platform: J-body
93 Cavalier, no power but battery has power
Old Nov 1, 2008 | 1:27 PM
mikelbeck's Avatar
Default 93 Cavalier, no power but battery has power
I've got a '94 Cavalier. The other day while driving the speedo dropped down to 0, then came back up. The radio went on and off a few times. Then the car died altogether. It won't start, won't spin the motor. The interior light doesn't work, the dashboard doesn't light up. Nothing.
I checked the voltage at the batter with a multimeter, it's got 12 volts. I followed the positive cable down to the starter, checked the voltage there and there doesn't seem to be any.
Should there be voltage at the stater? It looks like a straight shot from the battery to the starter so I would expect that there should be voltage there. Can the battery cable go bad?
Old Nov 30, 2008 | 5:58 AM
waltd140's Avatar
Default RE: 93 Cavalier, no power but battery has power
You should have voltage at the starter & alternater when the car is turned off. Check alternater voltage as well starter silionoid. Also, check to see if the serpintine belt is loose. Might be time for the tensioner.
jdracing
Oct 30, 2014 3:45 PM
JRich_taco
Oct 28, 2013 7:40 PM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
