Platform: J-body
95 Z24 2.3L Stalls while driving
Old Mar 24, 2012 | 2:25 PM
ShaunLB84's Avatar
Default 95 Z24 2.3L Stalls while driving
Car randomly stalls while driving, at low rpm giving gas or at high rpm giving gas. I have put a brand new fuel pump in it few days ago and still does this.
Car sometimes just cranks and cranks and cranks, I have to turn key off then back on for car to start and it will fire right up.
I don't know what else to check?
Has new fuel pump
new fuel filter
new ignition switch
new spark plugs
checked all fuses and replaced all relays
cleaned the engine ground
cleaned out throttle body
checked for vacuum leaks
cleaned out oil air separator
ran seafoam through vacuum to clean out injectors
Car has no check engine light and it doesn't get one when the car stalls. If I am going fast enough I can just turn key off then back on and it fires right up since it is a manual transmission.
Would a faulty Ignition control module cause this problem?
Would a faulty fuel pressure regulator cause this problem?
Old Mar 27, 2012 | 11:38 AM
ShaunLB84's Avatar
How can I test the fuel pressure regulator?
Old Apr 2, 2012 | 5:03 AM
freakville03's Avatar
when it stalls i would have it checked for codes. of course i'm sure that you will not be around an auto parts store when this happens.
Old Apr 4, 2012 | 12:35 PM
ShaunLB84's Avatar
Put a new fuel pressure regulator on, didnt fix it. Took it back put the old one on.
Put a new ICM on the car, and the car runs like new! Its finally fixed.
Joe JR
Aug 3, 2023 11:58 AM
Kahuna6719
31
Apr 11, 2021 3:35 PM
99SuburbanTX
Sep 9, 2012 5:09 PM
oilyfishhead
Apr 1, 2011 5:11 PM
