Platform: J-body
98 Cavalier cold start problems
Old Jul 30, 2013 | 6:53 PM
certifieddude's Avatar
Default 98 Cavalier cold start problems
My 1998 Cavalier has a rather frustrating problem, whenever its left to sit for awhile it has a very long crank. If I restart it after a long crank it fires up immediately and will start immediately if left to sit for up to around 15 minutes, any longer then that and the long crank comes back.
I have noted a smell of gas after a long crank start.
Car info:
Year: 98
Engine: 2.2L 4 cyl
Model: 4dr sedan, base trim
Things that have been replaced: Fuel Pump, fuel filter, pcv valve, spark plugs and wires, crankshaft sensor and camshaft sensor.
Other than that it runs nice and there are no other problems, but this long crank is pretty frustrating and probably not good for the start motor.
Old Jul 30, 2013 | 7:34 PM
the injectors may be leaking down into the combustion chambers. If the car starts better in clear flood mode (accelerator held to floor) check for injector leak down.
-install a fuel pressure gauge
-prime the fuel system by cycling the key from off to run
-note the fuel pressure
-watch for pressure drop
Old Jul 30, 2013 | 8:57 PM
I tried starting it as you suggested and there was no difference, still a very long crank. I guess that narrows it down, but its just overwhelming how many different things it seems it could be.
Old Jul 30, 2013 | 9:15 PM
MDTAHOE's Avatar
Professional Mechanic
After it has been sitting (when it would hard start) pull the vac line off the fuel pressure regulator to see if there is raw fuel inside the line.
jstreet
Feb 18, 2012 7:14 AM
2009Sierra
Nov 11, 2009 6:15 PM
Thermool
Jun 20, 2009 6:41 PM
izod
Feb 14, 2009 2:42 PM
97Tahoe31
Jul 24, 2007 1:17 PM
