Platform: J-body
AFT Capacity
Old Dec 26, 2023 | 7:20 PM
44lawrence's Avatar
Default AFT Capacity
I'm changing the ATF & in pan filter in my 04 Cavalier with Mobil 1 LV ATF HP. Does anyone know how many quarts I should have "on hand" ? I have 6 qts. but just wondering if that's enough to come out the overflow check. Thanks
Larry
Old Dec 26, 2023 | 8:05 PM
did you check in your owner's manual?
Old Dec 28, 2023 | 2:00 PM
44lawrence's Avatar
Yes I checked the owners manual, it read 9qts for a total trans rebuild. I believe/guess my last ATF & filter change was around 7qt. ..
Old Dec 28, 2023 | 2:21 PM
I would have a couple more quarts on hand, and then just return whatever you don't use.
Old Jan 21, 2024 | 7:01 AM
SteveProTestdriver/'s Avatar
Default 7 quarts with fluid/filter change. Dexron 3/6 Fluid only.
Originally Posted by 44lawrence
I'm changing the ATF & in upan filter in my 04 Cavalier with Mobil 1 LV ATF HP. Does anyone know how many quarts I should have "on hand" ? I have 6 qts. but just wondering if that's enough to come out the overflow check. Thanks
Larry
Use a new Fel Pro or OEM gasket 2 time down.
tazassape
Jun 23, 2015 12:43 PM
2004cav
Oct 26, 2008 8:21 AM
Clint S
Feb 16, 2007 10:32 PM
06NBPsi
Oct 11, 2006 2:40 PM
cctgene
Jan 24, 2006 2:11 PM
