Platform: J-body
Air Conditioning causing engine to overheat
Old Jul 29, 2011 | 2:36 PM
06hhr's Avatar
Default Air Conditioning causing engine to overheat
2001 Cavalier, 2 door, manual transmission-
On the highway I can use the air conditioning with everything normal.
When in town, stop and go driving, the engine temperature will climb also I hear a hissing sound coming through the vents and the air is not cool. I also hear a tick come from engine.
When the car comes to a stop it does this but when I drive the air conditioning will work (blow cold air), temp will stay up. It just does at stops.
Please help, thanks!
Old Jul 29, 2011 | 2:40 PM
kevinkpk's Avatar
I'd say a/c compressor is perhaps low on charge, or probably is going out.
Old Jul 29, 2011 | 7:08 PM
EinST's Avatar
It sounds like there's a problem with the cooling system. Does the cooling fan run? Does the A/C compressor run? When there no air flow through the A/C condenser and radiator, the refrigerant pressure will rise and the PCM will disengage the A/C compressor at some point.
Old Jul 30, 2011 | 6:48 PM
Segfault's Avatar
I second EinST. Regarding cooling fan. Compressor obviously runs if you get cool at higher speeds.
MSBoats
Oct 24, 2011 9:13 PM
spiritoflife
Apr 30, 2011 1:50 PM
tdavetice
Aug 19, 2007 8:06 PM
goon
Jun 3, 2007 5:36 PM
